Last fall I was able to use the ArcGIS extension for Illustrator to save a web map, import it into the program, and sync it to produce vector map elements.
I updated to Illustrator 2023 a couple of months ago and lost the extension, so I downloaded the current version and installed today. Now, when I go to sync a map to the artwork layers, it doesn't load any of the elements except for the copyright stamp. Otherwise, it's a blank white canvas and the layers are empty. I'm not getting any sort of error code...it tells me it's syncing successfully every time.
If I switch to the legacy mapping profile, it's able to produce PART of the content (in this case, paths for a trail map), but not the topography layer, so that doesn't help me much.
Appreciate any help.
