I am having an issue with publishing a Map to AGOL as a web map.
I am being told it is a "Consolidation Error". I tried shortening the file path by moving it from a folder buried in multiple other folders to the desktop. But I am getting the same error. Here is the JobLog:
Cruise Map 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:07 Status: InProgress StatusMessage: Successfully wrote sharing info file
Cruise Map 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:07 Status: InProgress StatusMessage: Creating thumbnail from map
Cruise Map 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:07 Status: Pending StatusMessage: Sharing process started
Cruise Map 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:07 Status: InProgress StatusMessage: Sharing process started
Cruise Map 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:07 Status: InProgress StatusMessage: Reading thumbnail from file
Cruise Map 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:08 Status: InProgress StatusMessage: Extracting all manifests from the configuration of the web map/scene
Cruise Map 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:08 Status: InProgress StatusMessage: Publishing individual web layers
Cruise Map 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:08 Status: InProgress StatusMessage: Creating the type keywords for the web map/scene
Cruise Map_WFL1 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:08 Status: InProgress StatusMessage: Loading manifest
Cruise Map 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:08 Status: InProgress StatusMessage: Reading thumbnail from file
Cruise Map_WFL1 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:08 Status: InProgress StatusMessage: Publishing process started
Cruise Map_WFL1 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:08 Status: InProgress StatusMessage: Consolidating data and staging web layer
New folder\Cruise Map 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:09 Status: InProgress StatusMessage: Using ArcGIS Version 13.0 for staging (Source for version: GP Staging Parameters)
Cruise Map_WFL1 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:09 Status: InProgress StatusMessage: Stage Tool initialized
Cruise Map_WFL1 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:09 Status: InProgress StatusMessage: Preparing maps and layers for processing
Cruise Map_WFL1 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:09 Status: InProgress StatusMessage: Consolidate data
Cruise Map_WFL1 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:09 Status: InProgress StatusMessage: Staging feature service
Cruise Map_WFL1 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:13 Status: Failed ErrorMessage: Consolidation failed
Cruise Map 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:13 Status: Failed ErrorMessage: ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.
Cruise Map 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:13 Status: Failed ErrorMessage: Failed to execute (StageService).
Cruise Map_WFL1 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:15 Status: Failed ErrorMessage: Staging failed
Cruise Map 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:17 Status: Failed ErrorMessage: Failed to publish web layer Cruise_Map_WFL1.
Cruise Map 5 WebMap Lancaster Conservancy https://www.arcgis.com/ eroper9 2023-02-08 13:59:19 Status: Failed ErrorMessage: Failed to publish one or more web layers
Any help is appreciated.
