Dear all,
I am beginning to learn Survey123, and I am using the available ESRI template for Manhole Inspection to create a survey in which repeat data can be edited subsequently. The only modifications from the template was to disable the sent folder and enable the Inbox. I have also changed the survey to that everyone can have access to the survey, as well as to create, edit, delete records as well as access data.
When I enable the Inbox and I am logged with my ArcGIS account, the survey's operates as it would be expected. I can add data to the survey and Inbox is able to be refreshed.
However, when I do not sign in to my account, I can add new data to the survey and database, but when try to refresh the survey to retrieve an existing record for editing, nothing shows up in the Inbox. Am I making a mistake or is this a limitation of Survey123? I am sorry if this is a newbie question, this is really by first week learning Survey123. Any help is very appreciated.
