It would be great if the Trace Network ribbon had an option to calculate stream order (using vector layers, instead of running the Stream Order tool on stream and flow direction rasters). The current tools, such as Downstream and Upstream, are helpful, but there is much potential for expanding Trace Network functionality.
For context, I created a trace network using an NHD stream layer, which already has flow direction in the attribute table. I would like to identify all first-order streams (example streams highlighted in yellow in image). I need to use the regular NHD dataset, not NHDPlus (NHDPlus contains stream order data, but it is calculated differently than I want to).
