When collecting features using the mobile app, my workflow would have dramatically improved efficiency if points were automatically added when the "+" button is used. The issue with the current workflow is that I have to click the "+" to add a feature, select the value/values I want to submit, then select "Add Point", and finally select "Submit." You cannot successfully hit "Submit" unless you have previously already selected "Add Point." The point should automatically be added when hitting the "+" button and I should not need to select "Add Point." I would recommend that this should say "Update Point" if you want to move it and the point should automatically be added when selecting the "+."
The current workflow creates extra clicks when I only have seconds to log a point and I am logging thousands of points in a day.
