My understanding is that for the Location Referencing toolbar to appear in ArcGIS Pro 3.0.3 when using an Enterprise Geodatabase these requirements must be met:
- Location Referencing must be licensed
- Map view must be open, and that map must have three layers present that have as their source Feature Service Feature Classes for a network, its centerlines and calibration points
In an existing project I have a map view open, and I can see the Location Referencing (and Linear Referencing) tab present (as expected).
Into that project I insert a New Map, and into that map I use Add Data to add a layerfile named Route Editing Layers (DEV Portal).lyrx. As expected, the Location Referencing (and Linear Referencing) tab appears, and I can see the expected network, centerline and calibration point features classes and that their sources are feature service feature classes. I close that project without saving because it was only a test to prove the layer file does what I think it should.
I restart ArcGIS Pro without a template, and insert a New Map into it. I use Add Data to add the same layerfile named Route Editing Layers (DEV Portal).lyrx into that map. This time, the Linear Referencing tab appears but not the Location Referencing tab, even though I can see the expected network, centerline and calibration point features classes and that their sources are feature service feature classes.
Why might the Location Referencing tab fail to appear in the second test?
If I create a new project using the Map Template, and add the same layerfile into its only map, then the Location Referencing tab fails to appear there too. I am confident that in the past the second and third tests would have produced the expected result and am at a loss as to why even with several laptop and ArcGIS Pro restarts this problem has emerged and remains.
