I am using a map series to create a PDF that illustrates different attributes of each feature. This requires that there are multiple map frames and charts per page showing the same feature but symbolized on a different attribute (this part is easy to set up and is working). To be able to create the report we actually want, we would need more than 1 page per feature. Example: the 1st page related to feature 1 would contain information and map frames about attribute A and attribute B, and the 2nd page related to feature 1 would contain information and map frames about attribute C and attribute D.
It would be great to be able to have the option to add or link more page layouts to the map series, and the features in these page layouts would still be linked to the map series (same as on the initial page layout). These additional layouts would be included for each feature when the map series print. These additional pages would make it possible to show more information of the feature without having to create 2 (or more) separate map series PDFs and then combining them manually into 1 final PDF.
The solution I would be looking for is a solution that is contained within ArcGIS Pro and doesn't require scripting or workarounds.
