I deployed the new Electric Joint Use Solution to play with and see if it's something that could work for our organization. 52 separate items were deployed to a folder on AGOL.
I guess I'm a little confused. I haven't ever deployed one of these solutions before. Is there documentation or metadata somewhere that describes the purpose of each item, its schema, relationships, etc? We have existing data that I need to load into the solution feature layers. There are many more fields than we track currently, but it's not clear which ones will be required or used by other items in the solution, what values the fields should take, or how they are intended to be used.
I can give an example. The Pole feature layer contains a field called assettype. The field has no domain applied, does not allow null, and is of short numeric type. What am I supposed to do with that field? How do I map fields in my existing data to it if I have no idea of its purpose? The esri solutions page is very brief and unhelpful. https://doc.arcgis.com/en/arcgis-solutions/latest/reference/introduction-to-electric-joint-use.htm
