So I got my script to work but it is still giving me a problem.
When i run the script through command line it is printing out the elif clause about 10-15 times each before it starts to delete fields. Anyone have any advice?
import arcpy
fieldList = ['ID','LAT','LON','AREA','PARIMETER','Hectares','CODE',
'WEBCODE','DATE_','TIME_','SURVEYOR','TYPE','REV_DATE',
'DATA_SRC','PATTERN','SWATH_DIST','VIEW_DIRC','CONDITIONS',
'CONFIDENCE','RPT_YR','SURVEY_ID1','SURVEY_ID2','SURVEY_ID3',
'DMG_TYPE1','DMG_TYPE2','DMG_TYPE3','SEVERITY1','SEVERITY2',
'SEVERITY3','PATTERN1','PATTERN2','PATTERN3','TPA1', 'TPA2',
'TPA3','NO_TREES1','NO_TREES2','NO_TREES3','NOTES','NOTE',
'DAMAGE94_','DAMAGE94_I','STATUS','MODIFIIER','ACRES',
'PESTNUM','MODNUM','GRP1','GRP2','GRP3','SURVEY_YR','RPT_RGN',
'R295_DMG_I','R295_DMG_','R2_PC3','R2_PC2','R2_PC1','R201_DMG_',
'R201_DMG_I','AREA_METER', 'SOURCETHM','PCT_MORT1','PCT_MORT2',
'PCT_MORT3']
arcpy.env.workspace = r'H:\GIS DATA\Data\Pine Beetle\Beetle\Test'
fcs = arcpy.ListFeatureClasses()
for fc in fcs:
for i in fieldList:
x = arcpy.ListFields(fc)
for a in x:
if i == a.name:
arcpy.DeleteField_management(fc, i)
print i + ' was deleted from ' + fc
elif i != a.name:
print i
