Hi Guys,
On my map i want to select multiple layers by drawing rectangle and than export selected features fields. i have this code thanks to @BlakeTerhune (From my previous topic😞
// create a new sketch view model set its layer
const sketchViewModell = new SketchViewModel({
view: view,
layer: polygonGraphicsLayerr
// Once user is done drawing a rectangle on the map
// use the rectangle to select features on the map and table
sketchViewModell.on("create", async (event) => {
if (event.state === "complete") {
// this polygon will be used to query features that intersect it
const geometriess = polygonGraphicsLayerr.graphics.map(function(graphic){
return graphic.geometry
const queryGeometry = await geometryEngineAsync.union(geometriess.toArray());
selectFeatures(queryGeometry);
// This function is called when user completes drawing a rectangle
// on the map. Use the rectangle to select features in the layer and table
function selectFeatures(geometry) {
// create a query and set its geometry parameter to the
// rectangle that was drawn on the view
var query = {
geometry: geometry,
outFields: ["*"]
map.allLayers.forEach(layer => {
// Query all layers data
layer.queryFeatures(query)
.then((results) => {
// do something with query results
console.log(results)
.catch(errorCallback);
When i draw rectangle in logs i get error: layer.queryFeatures is not a function;
what i do wrong? What is wrong here and i can not see? Help
