Hi
I am currently using WMTS to display satellite data and we used bearer token previously. We are now moving to API Key usage with WMTS and setting the API key with custom params or
ArcGISRuntimeEnvironment.setApiKey("MY_KEY")
wmtsService.customParameters["APIKEY"] = "MY_KEY"
is not working. Keep getting authentication errors, such as ""No API key provided".
What I currently have is
private val wmtsService: WmtsService by lazy { WmtsService("https://api.airbus.geoint.africa/api/v1/map/imagery.wmts")
wmtsService.customParameters["APIKEY"] = "MY_KEY"// create a Map
val map = ArcGISMap()
// set the map to be displayed in this view
mapView.map = map
// display wmts data on the map
wmtsService.addDoneLoadingListener {
if (wmtsService.loadStatus == LoadStatus.LOADED) {
// get service info
val wmtsServiceInfo = wmtsService.serviceInfo
// get the first layers id
val layerInfos = wmtsServiceInfo.layerInfos
// create WMTS layer from layer info
val wmtsLayer = WmtsLayer(layerInfos[0])
// set the basemap of the map with WMTS layer
map.basemap = Basemap(wmtsLayer)
if (wmtsService.loadStatus == LoadStatus.FAILED_TO_LOAD){
Log.e("ARCGIS", "Load failed: ${wmtsService.loadError.cause}")
wmtsService.loadAsync()
It keeps failing and I get a grid of grey squares from the map view, any help would be appreciated.
