Hello @SarahBell, I was reading your piece about improving mapping workflows and I wondered if you have some advice about dealing with maps with a lot of layers?
Right now I'm exporting an .aix file from ArcGIS Pro. It's intended to be a 3.5m x 2.5m print map and includes a lot of data for admin boundaries, towns, roads, heights etc.
Once the aix has been generated opening in Illustrator takes about 15 mins (on a reasonably powerful machine) and although rendering does complete it's vitually unusable after that with long waits between turning layers on an off.
Do you have any adivce for this scenario?
I had wondered whether I could export selected layers to multiple .aix's and then only work on a given set in Illustrator at a time, and or perhaps rastering a set of layers so I could work on other but still see those rasterized one - is that feasable?
All advice gratefully accepted!
John
