Hi all,
I have a Pro project that has a lot of layers. I need to produce a lot of PDF plans from the map frame everyday but both the print (to PDF ) or Export to PDF takes far too long to be of use. I would say on average each plan is taking between 5-10 mins. Does anyone have any idea what might be causing this process to run so slowly? I work for a Council and all the layers are stored on the SDE or as map services in portal. This isn't a problem specific to me, all employees have the same issue.
Thank you
Dave
