CORS yet again - totally fed up now with this.
I HAVE to use API 3.11 - see Re: Measure Tool no longer gives result on mouse M... - Esri Community due to a bug in the measure tool.
We are migrating to a new server so having fun with CORS, yet again.
Everything works until I try to print. Then I get
esri.config.defaults.io.proxyUrl is not set. If making a request to a CORS enabled server, please push the domain into esri.config.defaults.io.corsEnabledServers
No hint as to WHAT domain needs pushing.
This works if I go to the latest 3.x api.
So, I listed out what is in corsEnabledServers in the latest api and compared with what I had in 3.11 and pushed all the others in. Still nothing. Although I couldn't work out how to push '/^https?:\/\/.+\.arcgis\.com(\/|$)/i, ' which is present in the latest version.
Any ideas?
Cheers
ACM
