I'm encountering some odd results when using the search() method in the ArcGIS API for Python, and I don't know if this is due to user error or something else.
When using the search() method to isolate items of "type: Feature Service" within a group, depending on what "max_items" is set to, there is a drastically changes in what gets returned under "results" in the dictionary. The "total" seems to remain the same correct value regardless, but individual feature services are duplicated in the returned results to varying degrees .
For context, I am querying feature services from a group within our AGOL organization, and the expected number of returned results is 133. If max items is set to 200 or below, the returned number of results seems to remain correct. If max items is set to anything higher than that value up to 233, the result count will always match max items. Any max items amounts higher than 233 produces varying numbers of results.
Am I just understanding the functionality of these parameters incorrectly, or is this not intended behavior?
Thanks!
