We are trying to integrate the ESRI Maps in a React Application. Using ARCGIS API for JS 4.24, we are able to draw the map and add features like marker and boundary on the map.
Now, we need to edit the geometry on the map by performing various operations like draw polygon, circle, split, move , delete etc. We could not find anything in the ARCGIS API for JS 4.24.
The document has some examples for ARCGIS API for JS 3.42 but in this case we are not able to render the map.
Using the code like below , we are getting the error : "Module not found: Error: Can't resolve 'esri/Map'"
import Map from "esri/Map";
map = new Map("map", {
basemap: "streets-vector",
center: [-15.469, 36.428],
zoom: 3
Any help regarding implementing the feature would be appreciated
