Any ideas on how to fix this error?
Extract Roof Form
Parameters
Buildings Buildings_Web
Elevation Surface (DSM) DSM_Meters
Ground Elevation Surface (DTM) C:\Users\slfernandez\Documents\ArcGIS\3DBasemaps\3DBasemaps.gdb\DTM_meters_Web
Normalized Elevation Surface (nDSM) HAGL_Meters_Web
Create Flat Roofs Only false
Minimum Flat Roof Area 250
Minimum Slope Roof Area 75
Minimum Roof Height 8
Output Building Polygons C:\Users\slfernandez\Documents\ArcGIS\3DBasemaps\3DBasemaps.gdb\BuildingsTT
Simplify Buildings true
Simplify Tolerance 0.1
layer1
first_time false
previous_layer Buildings_Web
first_time_dsm false
Messages
Start Time: Tuesday, October 18, 2022 2:54:26 PM
ArcGIS Pro version: 3.0.2
Project Home Directory is: C:\Users\slfernandez\Documents\ArcGIS\3DBasemaps
Creating buildings with roof forms.
Selecting features that have valid DTM and DSM values.
Only features that have valid DTM and DSM values will be processed and the output will be a new polygon feature class called: C:\Users\slfernandez\Documents\ArcGIS\3DBasemaps\3DBasemaps.gdb\BuildingsTT_roofform.
262 features of the 262 will be processed based on the available DTM and DSM.
Repairing geometries...
Calculating unique object ID...
Calculating Minimum Height Threshold DSM...
Creating Roof Plane Polygons...
Creating Aspect Planes...
Determining Minimum Building Elevation...
No sloped plane features detected:
Creating Flat Roof Slope Polygons...
Calculating Flat Roof Area...
Calculating Maximum Roof Plane Heights...
ERROR 010151: No features created by operation.
Failed to execute (ZonalStatistics).
Error on line 2363
Error in file name: C:\Users\slfernandez\Documents\ArcGIS\3DBasemaps\scripts\bm_common_lib.py
with error message: AttributeError: Object: Error in parsing arguments for Exists
ERROR:root:Error on line 2363
ERROR:root:Error in file name: C:\Users\slfernandez\Documents\ArcGIS\3DBasemaps\scripts\bm_common_lib.py
ERROR:root:with error message: AttributeError: Object: Error in parsing arguments for Exists
Failed script Extract Roof Form...
Failed to execute (ExtractRoofForm).
Failed at Tuesday, October 18, 2022 2:55:54 PM (Elapsed Time: 1 minutes 27 seconds)
