Hi there,
I have a colleague who wants to use a line feature in field maps to map a path. In particular, he likes that he can stream as he collects this line feature, making it very fast in the field. That's easy enough to set up, however he also wants to have a timestamp for each vertex of the line feature.
I have no idea how to do this, except to suggest that he really should use a point feature to collect his path, and then later derive a line feature from those points.
Does anyone know if there is a way to get the output he needs? If collecting points is the only way, is there a way to stream when collecting points?
Thank you!
Emiko
