Hi all,
When using the stormwater UN foundation solution, I noticed that the default value for the spatialsource field, in the database and for the feature editing templates, is set to Unknown. I have an attribute rule written that populates the spatialsource field with the last value an editor used, but the default value of Unknown is overriding my attribute rule value when I create features using the editing template. I have changed the default value for spatialsource at the subtype and field level in the database, but the template when creating a feature still uses that default Unknown value. I can get around this if I edit the template itself to remove the default value, but I have several other features with the same situation.
Essentially my question is:
- Is there a way to have the editing template pull from the default field value in the database? (as set in the subtypes or fields)
- OR, is there a way to batch update the editing templates? to remove the Unknown default value for the spatialsource field?
Otherwise, it seems I'll need to update the editing template for all features individually that use the last value attribute rule
Any help is appreciated!
