Hi all,
I don't think this is possible in ArcGIS Pro, but I thought I would ask. Can you filter the records shown for a feature based on what labels the maplex engine is showing? The use case is if I have only some streets labeled on a map due to maplex settings I then might need to create a street index based on only the visible labels. If the table would automatically filter the records then it would make creating the street index for a city or county map much easier. By the same reasoning if you could filter the records by display filter that would also be useful, is that also possible?
Cheers,
Dale
