Hello all,
I am converting labels to annotation in ArcGIS Pro 3.0.2. In the help https://pro.arcgis.com/en/pro-app/latest/help/mapping/text/converting-labels-to-annotation.htm it says below:
"Decide which extent contains all the labels you want to convert. Specify this on the Convert Labels To Annotation tool.
- Default—The full extent of the map or the custom full extent, if set.
- Union of Inputs—The extent is based on the maximum extent of all input layers.
- Intersection of Inputs—The minimum area common to all input layers.
- As Specified Below—Specify the minimum and maximum extent values.
- Current Display Extent—The extent is equal to the map or visible display.
- Same as Layer—The extent for a layer or dataset on disk is used. "
So when I use this tool my default extent is "Current Display Extent". Shouldn't my Default extent be "Default"? I don't understand the use of the word default if it's not default. Maybe the software means "Full Extent" and we're supposed to know that the default is Current Display Extent? I really don't know.
This tripped me up multiple times in a row as I wondered where all of my annotation went and why the tool didn't create all of my annotation.
Any help appreciated.
