Good day.
I am experiencing some strange behaviour from a Notebook in ArcGIS Online.
I want to convert a related table into a pandas dataframe. when I run this script locally on my machine it runs fine:
from arcgis.gis import GIS
from arcgis.features import FeatureLayerCollection
import tempfile
import pandas as pd
from datetime import datetime, timedelta
import numpy as np
# ArcGIS Online Login
gis = GIS(url='https://xyz.maps.arcgis.com/', username='xyz', password='xyz')
#create a temp scratch workspace
tmpdir = tempfile.TemporaryDirectory()
download_folder = tmpdir.name
fl = gis.content.get('8fbdac5a21ae4fa8a72b7fb6bd96e6ca')
items = fl.tables[0]
df = pd.DataFrame.spatial.from_layer(items)
print(df)
Yet when I run this slightly amended version in ArcGIS Online from a notebook:
import tempfile
import pandas as pd
import numpy as np
gis = GIS("home")
print(df)I get the following error:
IntCastingNaNError Traceback (most recent call last)
File /opt/conda/lib/python3.9/site-packages/arcgis/features/geo/_accessor.py:2688, in GeoAccessor.from_layer(layer)
2686 from arcgis.features.geo._io.serviceops import from_layer
-> 2688 return from_layer(layer=layer)
2689 except ImportError:
File /opt/conda/lib/python3.9/site-packages/arcgis/features/geo/_io/serviceops.py:187, in from_layer(layer, query)
186 raise ValueError("Invalid inputs: must be FeatureLayer or Table")
--> 187 sdf = layer.query(where=query, as_df=True)
188 sdf.spatial._meta.source = layer
File /opt/conda/lib/python3.9/site-packages/arcgis/features/layer.py:3720, in Table.query(self, where, out_fields, time_filter, return_count_only, return_ids_only, return_distinct_values, group_by_fields_for_statistics, statistic_filter, result_offset, result_record_count, object_ids, gdb_version, order_by_fields, out_statistics, return_all_records, historic_moment, sql_format, return_exceeded_limit_features, as_df, having, **kwargs)
3718 import pandas as pd
-> 3720 df = self._query_df(url, params)
3721 dt_fields = [
3722 fld["name"]
3723 for fld in self.properties.fields
3724 if fld["type"] == "esriFieldTypeDate"
3725 ]
File /opt/conda/lib/python3.9/site-packages/arcgis/features/layer.py:3308, in FeatureLayer._query_df(self, url, params, **kwargs)
3307 if dtypes:
-> 3308 df = df.astype(dtypes)
3310 if "SHAPE" in featureset_dict:
File /opt/conda/lib/python3.9/site-packages/pandas/core/generic.py:5799, in NDFrame.astype(self, dtype, copy, errors)
5797 if col_name in dtype:
5798 results.append(
-> 5799 col.astype(dtype=dtype[col_name], copy=copy, errors=errors)
5800 )
5801 else:
File /opt/conda/lib/python3.9/site-packages/pandas/core/generic.py:5815, in NDFrame.astype(self, dtype, copy, errors)
5813 else:
5814 # else, only a single dtype is given
-> 5815 new_data = self._mgr.astype(dtype=dtype, copy=copy, errors=errors)
5816 return self._constructor(new_data).__finalize__(self, method="astype")
File /opt/conda/lib/python3.9/site-packages/pandas/core/internals/managers.py:418, in BaseBlockManager.astype(self, dtype, copy, errors)
417 def astype(self: T, dtype, copy: bool = False, errors: str = "raise") -> T:
--> 418 return self.apply("astype", dtype=dtype, copy=copy, errors=errors)
File /opt/conda/lib/python3.9/site-packages/pandas/core/internals/managers.py:327, in BaseBlockManager.apply(self, f, align_keys, ignore_failures, **kwargs)
326 else:
--> 327 applied = getattr(b, f)(**kwargs)
328 except (TypeError, NotImplementedError):
File /opt/conda/lib/python3.9/site-packages/pandas/core/internals/blocks.py:591, in Block.astype(self, dtype, copy, errors)
589 values = self.values
--> 591 new_values = astype_array_safe(values, dtype, copy=copy, errors=errors)
593 new_values = maybe_coerce_values(new_values)
File /opt/conda/lib/python3.9/site-packages/pandas/core/dtypes/cast.py:1309, in astype_array_safe(values, dtype, copy, errors)
1308 try:
-> 1309 new_values = astype_array(values, dtype, copy=copy)
1310 except (ValueError, TypeError):
1311 # e.g. astype_nansafe can fail on object-dtype of strings
1312 # trying to convert to float
File /opt/conda/lib/python3.9/site-packages/pandas/core/dtypes/cast.py:1257, in astype_array(values, dtype, copy)
1256 else:
-> 1257 values = astype_nansafe(values, dtype, copy=copy)
1259 # in pandas we don't store numpy str dtypes, so convert to object
File /opt/conda/lib/python3.9/site-packages/pandas/core/dtypes/cast.py:1168, in astype_nansafe(arr, dtype, copy, skipna)
1167 elif np.issubdtype(arr.dtype, np.floating) and np.issubdtype(dtype, np.integer):
-> 1168 return astype_float_to_int_nansafe(arr, dtype, copy)
1170 elif is_object_dtype(arr):
1171
1172 # work around NumPy brokenness, #1987
File /opt/conda/lib/python3.9/site-packages/pandas/core/dtypes/cast.py:1213, in astype_float_to_int_nansafe(values, dtype, copy)
1212 if not np.isfinite(values).all():
-> 1213 raise IntCastingNaNError(
1214 "Cannot convert non-finite values (NA or inf) to integer"
1215 )
1216 return values.astype(dtype, copy=copy)
IntCastingNaNError: Cannot convert non-finite values (NA or inf) to integer
During handling of the above exception, another exception occurred:
Exception Traceback (most recent call last)
Input In [5], in <cell line: 17>()
15 utr_items = predeploymnet_master_fl.tables[0]
16 print(utr_items)
---> 17 utr_df = pd.DataFrame.spatial.from_layer(utr_items)
18 print(utr_df)
File /opt/conda/lib/python3.9/site-packages/arcgis/features/geo/_accessor.py:2697, in GeoAccessor.from_layer(layer)
2692 raise Exception(
2693 "Malformed response from server, could not load the dataset: %s"
2694 % str(je)
2695 )
2696 except Exception as e:
-> 2697 raise Exception("Could not load the dataset: %s" % str(e))
Exception: Could not load the dataset: Cannot convert non-finite values (NA or inf) to integer
Can anyone please assist?
