Hi all
I am trying to set up a survey with some requirements, but I am not sure if what I would like to set up is even possible. I have read a lot of blogposts and questions, but I'm still not sure if it's possible or not.
We'd like external partners (without ArcGIS online accounts) to fill in a form when they are planning certain works (field: work=work planned), so we know when (field:date planned), where, what will be done. They need to provide an e-mailaddress so we can contact them if we want to. When the job is finished (field:work=work executed) they have to provide the date when the job was done (field:date executed).
If possible I'd like them to edit the form they already submitted (work planned). I have made a survey using connect, and I am using Power Automate to send an e-mail with a link to the form with the correct globalId, edit mode, and with the field:work set to work executed, so they only have to fill in the date executed when the job is done. I got this all working fine, the only problem is I have to adjust the settings of the feature layer to "editors can see all features" to make sure the form with the globalId will open and they can edit their own features. This means, anyone who finds these survey results can adjust all features and can see the e-mailaddresses. I'd like to limit viewing and editing to only those features they submitted themselves. It this possible?
Next thing is the people in my organisation would like to see (not edit) all features (including e-mailaddresses) in a Geocortex viewer, only open to people of my organisation, without using ArcGIS online credentials.
If what I would like to set up is just not possible, I'd have to change plans: let the public only add features (no editing), which means they have to submit a form when they are planning work and again another form when they have executed the work (I think I could provide a link in the e-mail with some fields already pre-populated, so the form looks the same as if they were editing the form they previously submitted). This also means I can change the settings to "editors can't see any features, even those they add" and data will be secured.
And to provide all features and information to my colleagues I would have to make an export regularly and publish it on our internal ArcGIS server, which is secured.
Any thougths and help very much appreciated.
Thank you.
Hans
