I am working on a survey with a repeat that needs to allow editing after the respondent has submitted their survey responses. So far, using URL parameters has enabled editing access when I type it in by hand, the only issue is when I try to use the link in a Dashboard or a Pop-up it'll pull the GlobalId from the repeat instead of the entire survey itself.
Example of the URL (with the survey id/portal url and globalid omitted): https://survey123.arcgis.com/share/ <Survey ID Here> ?portalUrl= <Portal URL Here> &mode=edit&globalId= <globalId Here>
Within the Dashboard, I have a list of the responses and when one is selected it'll filter the embedded survey to display the record to be edited. When I replicated the survey/dashboard in an AGOL account, it was set up so that the Source field's ParentGlobalID matched the Target field's GlobalID, but for the survey/dashboard created for the portal there is no ParentGlobalID within the source field (the repeat) that matches the target field / whole survey response. There is a ParentRowId that matches the RowID, but when the dashboards use the RowID for the target field it displays the following error:
Error: Editing is not possible because the globalId parameter was not provided
So to work around this, I tried to create a new field within the survey's repeat to pull to whole survey's GlobalID (which I called parent_row_globbalid), so that I could set the source field to parent_row_globalid and the target field to the GlobalID, but I haven't had any luck finding references to how to pull the GlobalID. I am open to other suggestions, I basically need the URL to be populated with the survey's GlobalID based off of the record selected from within the repeat (to configure a pop-up with the URL) and/or a field within the repeat to pull the GlobalID from the whole survey (to filter the embedded survey within the dashboard).
