Our survey is not able to retrieve the data from repeats on previously submitted surveys using the outbox. All other fields and pictures retrieve data, but the repeats do not. The survey does have "allowUpdates=true query" in the "bind::esri:parameters" column.
This is a significant problem because if the previous records are not retrieved and the user resubmits the data through the Outbox then we can end up with duplicate records. @IsmaelChivite @JamesTedrick
