I'm comparing two versions of a feature class one of which has <Null> spelled out in blank fields and the other just has blanks. Because of this difference, when I run the Detect Feature Changes tool, every feature shows up as having (at minimum) an attribute change. I want to want to run some python code to change either all <Null> to (blank) or vice versa so I can tell which features have been significantly changed. Is there an advantage to one or the other?
Matt
