The company i'm working for uses QR codes on trees in order to track them.
Each tree is a point on a map.
Is it possible to generate a hyperlink that will open the right tree on the map?
I would like to use this hyperlink to print on a QR code, or to build my own solution that will take an ID from the QR code and built the URL for it.
Is there any other solution?
Again: my main objective is to be able to scan a code on an actual tree and view it's data on the hosted layer.
** This does not have to use the fieldmap.
Thank you.
