HI,
I have a custom widget built in EB 1.8. It selects points and zoom to the selection. It was successfully running in EB 1.8.
I have recently upgraded to EB 1.9, client and server from cmd, successfully starts the widget.
In 1.9, it selects the features, but does not zoom to that location.
to zoom:
const extent = geometryEngine.union(sectionGeometries).extent;
this.mapView?.goTo(extent);
The above JS API reference (goto) is used. But, I suppose its not importing the engine and sectiongeometries variable which saves the section polygons is not storing the object.
The same code works in 1.8
import geometryEngine from 'esri/geometry/geometryEngine';
import Polygon from 'esri/geometry/Polygon';
import Graphic from 'esri/Graphic';
the above three modules are greyed out.
npm v 8.11.0
node v16.16.0
private sectionHighlightSymbol, the vriable is also greyed out. Should i declare the variable differently? I wen through the breaking changes list,
https://developers.arcgis.com/experience-builder/guide/whats-new/#breaking-changes
I don't find any changes for methods used in my widget.
Any help is greatly appreciated.
