Hi everybody,
I can't use the method .watch (reactiveUtils.watch)
and I do not know why.
Classic JS ( with js api 4.20 ) and watchUtils.watch worked fine,
but with JS ( TypeScript - js api 4.24) I have problem.
And for completeness:
npm list
api-ts@1.0.0
\groupApp\appc
+-- @types/arcgis-js-api@4.24.0
+-- npx@10.2.2
`-- typescript@4.7.4
tsconfig.json:
"compilerOptions": {
"lib": ["ES2015","ES2015.Promise", "DOM"],
"module": "AMD",
"sourceMap": true,
"strict": true,
"target": "ES5",
"noImplicitAny": true,
"suppressImplicitAnyIndexErrors":true,
"esModuleInterop": true
I am attaching a piece of code from the file main.ts:
main.ts:
import ArcGISMap from "esri/Map";
import MapView from "esri/views/MapView";
import MIL from "esri/layers/MapImageLayer";
import rU from "esri/core/reactiveUtils";
const mapLay_1 = new MIL({
url:"https://..../MapServer",
title:"xyz"
map.add(mapLay_1);
view.when(() => {
mapLay_1.when(() => {
console.log("# info mapLay_1: ",mapLay_1) // I see, that is OK - layer is loaded
rU.watch(() => mapLay_1.visible, (visible) => {
console.log("??? reactiveUtils ??? >>>> ",mapLay_1.title, "visible:", mapLay_1.visible)
}) //view.when(
I have error in JS console:
Using ArcGIS API for JavaScript 4.24 [Date: 20220706, Revision: 7fd01dbc]
Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'watch')
Thank you for your help
Zdenek Procner
