Hi everyone,
I am learning Python development to help automate some of my regular data processes and am running into an issue.
I have table layer that will be regularly updated with new data, which I then am joining to a Parcel Geodatabase by a shared identifier.
I can do this in ArcGIS Pro by doing an AddJoin. When I have looked at the ESRI documentation to use manager.AddJoin for this, it seems to make sense, but I cannot get the scripting to work.
Here is the code that I am working on so far:
from arcgis.gis import GIS
from arcgis import features
from arcgis.features import FeatureLayer
import arcpy
import pandas as pd
import geopandas
import os
# Assigns ID for Feature Layer
rental_feature_ID = "c2af294c42284b89b1fbe9d633302161"
rental_feature_item = gis.content.get(rental_feature_ID)
rental_feature_item
rental_feature_item.tables[0]
table_url = "https://services6.arcgis.com/bdPqSfflsdgFRVVM/arcgis/rest/services/Rental Registry Auto-Update No Geocode/FeatureServer/0"
# I don't really understand this part, but it seems to allow you to reference properties from the parcel_layer
rental_table_layer = FeatureLayer(table_url)
rental_table_layer
# Assign ID for the most recent Parcel Map in the Portal
parcel_layer_ID = "e16339e911064240ad670b9f83ba0163"
# Assigns the Parcel Feature Layer to a variable
parcel_feature_layer = gis.content.get(parcel_layer_ID)
parcel_feature_layer.layers
layer_url = "https://services6.arcgis.com/bdPqSfflsdgFRVVM/arcgis/rest/services/Parcel_Map_Q1_2020/FeatureServer/0"
parcel_layer = FeatureLayer(layer_url)
parcel_layer
# Set local variables
inFeatures = parcel_layer
joinTable = rental_table_layer
joinField = "SBL"
#Trying to use ArcPy ValidateJoin
validate_join = arcpy.management.ValidateJoin(inFeatures, joinField, joinTable, joinField)
# Trying to use ArcPy Join
rental_joined_table = arcpy.AddJoin_management(inFeatures, joinField, joinTable, joinField)
rental_joined_table
The errors that I am getting are:
-Ffor the ValidateJoin function:
RuntimeError Traceback (most recent call last)
<ipython-input-17-dbab836410c9> in <module>
----> 1 validate_join = arcpy.management.ValidateJoin(inFeatures, joinField, joinTable, joinField)
C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py in ValidateJoin(in_layer_or_view, in_field, join_table, join_field, output_msg)
8654 return retval
8655 except Exception as e:
-> 8656 raise e
8657
8658
8651 from arcpy.arcobjects.arcobjectconversion import convertArcObjectToPythonObject
8652 try:
-> 8653 retval = convertArcObjectToPythonObject(gp.ValidateJoin_management(*gp_fixargs((in_layer_or_view, in_field, join_table, join_field, output_msg), True)))
8654 return retval
C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py in <lambda>(*args)
510 val = getattr(self._gp, attr)
511 if callable(val):
--> 512 return lambda *args: val(*gp_fixargs(args, True))
513 else:
514 return convertArcObjectToPythonObject(val)
RuntimeError: Object: Error in executing tool
- Error's I'm getting for the AddJoin Function:
<ipython-input-82-2745ba596294> in <module>
----> 1 rental_joined_table = arcpy.management.JoinField(inFeatures, joinField, joinTable, joinField, {joinField})
2 rental_joined_table
C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py in JoinField(in_data, in_field, join_table, join_field, fields)
8582 return retval
8583 except Exception as e:
-> 8584 raise e
8585
8586 gptooldoc('RemoveJoin_management', None)
8579 from arcpy.arcobjects.arcobjectconversion import convertArcObjectToPythonObject
8580 try:
-> 8581 retval = convertArcObjectToPythonObject(gp.JoinField_management(*gp_fixargs((in_data, in_field, join_table, join_field, fields), True)))
8582 return retval
513 else:
