Simple question. I'd like to build a survey that allows users to annotate different maps (pre-built web maps with different layers), based on their answer to a previous question. Is this workflow possible? If so, how? It seems like you can only annotate image questions, and while you can define the body::esri:style method as "map", you can't define what map to use.
