We have a small, simple Survey123 survey that I need to update when Corrective Auction Requests are completed. To do this I am using the inbox function so I can edit the fields.
A problem has arisen where some of the data isn't displaying when you view the form. The data is there as I can see it when I view the survey data via the Survey123 website. I can add more data to the field and its updated, however, the data can't be viewed using the inbox.
Annoyingly, the missing data isn't constant between forms.
1) all forms are missing the same field called CAR details
and
2) some forms have missing fields which vary between survey forms
The only consistent things is that always a text field.
I have looked at the xml file and I can't see anything obvious. The fields all have the same setting -text - multi line - fieldlength of 1000 which is standard across forms I have designed.
If you view the form through ArcGis Survey123 website you can't see the field. However if you go to edit the survey form in the website, you can see the field. Not sure if this is a problem or not. I have never noticed this before.
This form was working before the 3.14 app update. All entries and edits are done using a PC - not using the Survey123 app.
Andrew
