I'm working with API JS4.xyz and I need to create a scene with WMTS layer inserted into it. Is that possible? I cannot find any sample combining WMTS and Scene view.
I'm able to accomplish this using Portal for ArcGIS where I created WMTS item, then created scene (without original basemap, just with WMTS) and then to create WebScene using this portalItem. That works, but I loose the original basemap I have as default in Portal for ArcGIS.
The error I recieve when I try to add new WMTSLayer created via JS is: The tiling scheme of this layer is not supported by SceneView. Is there any workaround?
Thank you for any help!
Martin Porteš
