I was excited to see contingent values are now supported in Field Maps, but I am having a lot of trouble getting them to work. I've set up contingent values in ArcGIS Pro across 3 fields. The contingent values work perfectly in Pro, but when I uploaded the layer to ArcGIS Online, the contingent values all say "value combination is invalid" for combos that should be fine.
The strange thing is that the situation has seemed to get worse over time, each time I try to fix it. At first, the values all worked fine but I noticed an error I had made in the contingent values, so I fixed it in Pro and re-uploaded the layer. Then, the contingent values only work across the first two fields (that is, a selection in the first field provides the correct options in the second field), but they do not work from the second field to the third field.
Next, I rebuilt my contingent value files, deleted the field group in Pro and re-imported the values. They still work perfectly within Pro. So I reuploaded the layer to GIS Online, and now none of the three fields shows any valid value combinations.
I'm stumped.
