I am using the `combobox` and `input-date-picker` inside a panel. However the dropdown/popups don't display over the panel, they display inside it causing a scrollbar to be active on the panel and the date-picker/combo options not to be visible. This is not the behaviour I was expecting, when using a `select` the dropdown behaves as expected and is displayed on top of everythin else.
Am I using the componenets in the intended way?
Minimal example:
<calcite-panel heading="Heading" dismissible>
<calcite-input-date-picker locale="en-gb"></calcite-input-date-picker>
<calcite-combobox selection-mode="single" label="Combobox">
{% for item in item_list %}
<calcite-combobox-item text-label="{{ item.label }}" value="{{ item.value }}"></calcite-combobox-item>
{% endfor %}
</calcite-combobox>
<calcite-button slot="footer-actions">Save</calcite-button>
</calcite-panel>
