I try to use the Append GP tool in Pro to add record from source table to target table.
The tables are identical and I get the error:
ERROR 160228: The user does not have permission to execute the operation.
If I try to write a small python program that uses insert cursor I get similar problem.
The strange thing is that the same Append works for ArcMap with the same connection.
More then that I can run DeleteRows on this table without any problem.
Even more I can add records using pro just one by one.
Any ideas??
