Is there anyone able to add xlsx sheet to layer using ArcGIS Pro 3.0?
After I upgrade my ArcGIS pro 2.93 to 3.0, it just wasn't able to add any xlsx as standalone table. it also seem to have problem opening my past projects which utilize this feature.
Different from the error I used to get in 2.X when Microsoft Access Engine wasn't compatible, ArcGIS pro 3.0 doesn't return any error message when it had trouble adding xlsx sheet. It just keep trying loading and prevent you from closing the software.
Maybe I should conduct a clean re-install for better consistency, but I wonder if anyone is able to add xlsx using ArcGIS Pro 3.0.
