I have a layer with the symbology based off a certain field in the attribute table. In EB when doing an update to that field, it should change the symbology (in this case a red point to a green point), but it ends up taking a few minutes for that to happen. Is there the app can be configured to update the symbology/map immediately after the edit? To make the edit go through one has to click the "update" button so you would think that should be the trigger.
Thanks!
Matt
