I am just starting out using Trace Network after converting from Geometric Network. I am trying to figure out why my 'System Junctions' that appear at the end point of 2 lines with no valid point between them meet do not disappear after adding a valid point.
Steps to produce conditions:
- Find 2 line end points that meet with no valid point feature present.
- Add valid point feature at end points of said lines.
- Validate the trace network.
- The system junction error doesn't go away after validating even though I now satisfied the rules set for the Trace Network.
Am I missing a step?
I have already run the 'Enable Network Topology' tool as well.
I am using ArcGIS Pro 2.9.3. The data and Trace Network is located in a file geodatabase.
