I'm accessing a database owned by a different team. I'm trying to export the tables I'm interested in to create an object ID (the OID is currently being set as the primary key when I open the tables), and to allow me to join the tables to a spatial dataset.
When I run the Table to Table tool, it's generating a table but with the warning "000117: Warning empty output generated"
Could this be an issue with permissions around the database I'm accessing? I'm at a loss as to why else I wouldn't 'be able to create a copy of the table. I can successfully export a different table into the folder I'm trying to save to.
Thanks for your help
