Please consider having the Save button enabled when an attribute value is changed.
If you only edit the attribute table in pro, the save button is greyed out unless you hit enter key. Right now, I have to hit enter key after each entry. otherwise it might not be saved. I have to go back to double check after save edits. It is not efficient.
