I need to get an "actual" length of a path along a 3D surface. I've tried ADD SURFACE INFORMATION, ADD Z INFORMATION and a couple of tools from Spatial analyst (Path distance, thinking that might work) but nothing does. First used a DEM for the surface and realized the "data" was all 10m. apart, so probably messed that up, converted it to a TIN but keep coming up with the same results. Z distance is the same as using the "distance tool" or drawing a graphic line on the map. It's all 43 miles. !? Any ideas?
thanks!
Pete
