The geometry that is returned in arcade appears simplified to that which is returned by arcpy. At first I thought it was just dropping m values, but it is dropping z, m and curves. Is this just a limitation of Arcade or the Arcade Editor/ JS API? Any insight would be helpful.
This makes it tough to work with m values if I can't get to them in arcade.
I was going to hard code the geometry, but I think I'm having syntax issue with curvePaths as I get an error (illegal parameter)...
The geometry of a feature as returned by Arcade:
{"spatialReference":{"latestWkid":3857,"wkid":102100},
"paths":[[
[-9237699.298899999,4682788.039800003],
[-9237625.7377,4682783.805399999],
[-9237576.0275,4682781.260700002],
[-9237573.462399999,4682781.072500005], // missing circular arc info here...
[-9237540.4446,4682777.917100005],
The geometry of the same feature as returned via arcpy: Note: there are slight rounding differences as well
"curvePaths": [
[-9237699.2989061102, 4682788.0398060447, 0, 17895],
[-9237625.7377447672, 4682783.8054260481, 0, 18083.833599999998],
[-9237576.0275005512, 4682781.2606678447, 0, 18211.397599999997],
"c": [
[-9237573.4624214061, 4682781.0724902488, 0, 18217.989499999996],
[-9237574.7439314425, 4682781.1807280686]
[-9237540.4445814844, 4682777.9171169717, 0, 18302.990699999995],
"spatialReference": { "wkid": 102100, "latestWkid": 3857 }}
I'm attempting to create an expression that will determine offset distance and corresponding station/m value and the offset direction but hitting a wall trying to get the measures to work against.
