I am having trouble with the last phase of a script for a script tool: I cannot figure out how to delete my temporary gdb to close out the script. Having the program that's executing the script open retains a lock in the gdb...for instance when I close Jupyter (or VS code, or IDLE) I can see the lock file in the gdb disappear. How can I construct my code so this isn't an issue when made into a script tool?
There have a been a few other posts on this topic and none of those solutions seem to be quite right. The general advice has been to add an arcpy.env.overwriteOuput = True, and that has not been effective.
The code that creates the gdb:
#Create temporary Workspace
arcpy.AddMessage("\nCreating temporary workspace")
tempName = "incorp" + outVersion + "_TEMP"
tempGDB = os.path.join(outFolder, tempName + ".gdb")
arcpy.management.CreateFileGDB(outFolder, tempName)
arcpy.env.workspace = tempGDB
The script then goes on and does several operations within that temp gdb, clipping, erasing, querying, adding fields, etc. Then when I go to delete it...
#Delete intermediate data
arcpy.AddMessage("\nDeleting intermediate data")
todel = (tempGDB, union, lastIncorp_xml)
for dataset in todel:
if arcpy.Exists(dataset):
arcpy.management.Delete(dataset)
I get ERROR 000601 - Cannot delete [path].gdb. May be locked by another application. Failed to execute (Delete).
Any thoughts on what can be done so the tool can clean up after itself?
