We are using the latest version of Field Maps and have Enterprise 10.9.1. We are using ADFS for our SAML logins with our portal, and on our mobile devices (Android) we are using Citrix SSO for the tunneling aspect. Chrome is the default browser on the devices in the case I am discussing below.
We have a growing number of users that are unable to login to our enterprise environment. They enter the enterprise URL, enter in their credentials, and then get the error that I've attached to the post and are unable to login. In some cases, if you close that window & go through the login steps again it will let you into the portal. In other cases, they enter the portal url again and then get a connection error pop up. Once people get this error, they also experience it in Explorer & Collector.
Before they see this issue they would see an issue in Field Maps that has a little popup at the bottom that says 'No Portal Connection'. If they then log out out of Field Maps they would get the login issue I'm describing.
HAs anyone experienced anything similar?
