Using the StatusBar app template, if I add a footer of type TabBar to the App, it is pushed down below the screens painted area. If I exaggerate the height to 100 or more then the footer moves up into the view more. I'm just worried this may create an abnormally large footer on some devices.
/* Copyright 2021 Esri
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
import QtQuick 2.9
import QtQuick.Layouts 1.1
import QtQuick.Controls 2.2
import QtQuick.Controls.Material 2.2
import QtGraphicalEffects 1.0
import QtQuick.Dialogs 1.2
import QtQuick.Layouts 1.3
import ArcGIS.AppFramework 1.0
import ArcGIS.AppFramework.Platform 1.0
import "controls" as Controls
AppLayout {
width: 400
height: 750
delegate: App {
height: appLayout.height
width: appLayout.width
function units(value) {
return AppFramework.displayScaleFactor * value
property real scaleFactor: AppFramework.displayScaleFactor
property int baseFontSize : app.info.propertyValue("baseFontSize", 15 * scaleFactor) + (isSmallScreen ? 0 : 3)
property bool isSmallScreen: (width || height) < units(400)
StackView {
initialItem: landingPage
anchors.fill: parent
Component {
Page {
header: ToolBar {
width: parent.width
height: 50 * app.scaleFactor
Material.background: Material.color(Material.Purple)
Material.elevation: 0
Controls.HeaderBar{}
footer: TabBar {
contentHeight: 60 * app.scaleFactor
position: TabBar.Footer
background: Rectangle {
color: "blue"
TabButton {
height: 60 * app.scaleFactor
Text {text: "hey"}
TabButton {
Text {text: "hey"}
Rectangle {
anchors.margins: 5 * app.scaleFactor
color:"#F5F5F5"
// sample starts here ------------------------------------------------------------------
ColumnLayout {
spacing: 20 * app.scaleFactor
Item {
Layout.preferredHeight: 20 * app.scaleFactor
ComboBox {
Layout.alignment: Qt.AlignHCenter
displayText: "Color: " + currentText
currentIndex: Material.Purple
Layout.preferredWidth: parent.width * 0.7
model: ListModel {
ListElement { name: "Red" }
ListElement { name: "Pink" }
ListElement { name: "Purple" }
ListElement { name: "DeepPurple" }
ListElement { name: "Indigo" }
ListElement { name: "Blue" }
ListElement { name: "LightBlue" }
ListElement { name: "Cyan" }
ListElement { name: "Teal" }
ListElement { name: "Green" }
ListElement { name: "LightGreen" }
ListElement { name: "Lime" }
ListElement { name: "Yellow" }
ListElement { name: "Amber" }
ListElement { name: "Orange" }
ListElement { name: "DeepOrange" }
ListElement { name: "Brown" }
ListElement { name: "Grey" }
ListElement { name: "BlueGrey" }
delegate: ItemDelegate {
text: modelData
width: colorBox.popup.width
Rectangle {
parent: colorDelegate.background
color: Material.color(index)
onCurrentIndexChanged: {
StatusBar.color = Material.color(colorBox.currentIndex)
ComboBox {
displayText: "Theme: " + currentText
currentIndex: Material.Dark
model: ListModel {
ListElement { name: "Light" }
ListElement { name: "Dark" }
text: modelData
width: themeBox.popup.width
StatusBar.theme = themeBox.currentIndex
Button {
text: "reset"
onClicked: {
StatusBar.theme = Material.Dark
themeBox.currentIndex = Material.Dark
StatusBar.color = Material.color(Material.Purple)
colorBox.currentIndex = Material.Purple
Item {
Layout.preferredHeight: 10 * app.scaleFactor
Label {
text: "Note: Status bars are not displayed by default on devices; it first has to be enabled by setting the property display.statusBar to true in the app's appinfo.json."
wrapMode: Label.Wrap
Item {
Layout.fillHeight: true
Layout.fillWidth: true
contentItem: Rectangle {
anchors.top:header.bottom
// sample ends here --------------------------------------------------------
Component {
Controls.DescriptionPage {
Component.onCompleted: {
