I feel the addition of a default "Yes/No" question would be quite useful and time saving within the Survey123 web app. Having it as an option would eliminate quite a few extra steps needed to create this option out of the standard "Single Choice" option. Currently if you want a simple Yes/No each time you create that you need to go through the following:
rename choice 1 to yes
rename choice 2 to no
delete choice 3
set to horizontal(not required but is a cleaner layout for this question)
This sounds small but when making a survey with dozens or even up to 100 questions of this type it becomes tedius.
Thank you for your consideration in this matter
