I have created a web mapping application (using Web AppBuilder) which enables the attribute table for the layers it contains to be viewed at the bottom of the map screen, and the data exported to csv via the 'Options' button at the top of the attribute table. Which works as expected.
However I have then imbedded this map as a tab in a AGOL dashboard (so its accessible to users in the same place as other dashboard summary data), but it now appears that you can no longer export the data to csv? I still get the option to export the data as above, but on confirming 'OK' nothing then happens?
Is this a bug or is there any reason why you can't export data from a web map once its embedded into a dashboard?
Grateful for any advice,
Katie
