Hello! I'm looking for some help with one of my data expressions in ArcGIS Dashboards.
I have four layers published to a feature service, which I'm trying to combine. The catch is that I only want the output feature set to include records from 'the past week.' Is there a way to do this using the Filter() function in a data expression?
My understanding is that the Arcade Filter() function uses SQL language for the query, and I can't figure out how to make a SQL query that parses the week number from my date field and compares it to the current week number. Below is an example of a successful script I'm using. I want to change the portion of line 1 where it says SURV_DATE IS NULL to essentially say WEEK(SURV_DATE) = WEEK(CURRENTDATE()). Is this even possible? If so, what's the correct translation? If not, how would I alter my script to achieve this?
var sql = "SURV_DATE IS NULL And (EXEMPT_COD IS NULL Or EXEMPT_COD = 2 Or EXEMPT_COD = 4)"
var fs_flexible = FeatureSetByPortalItem(Portal('https://xyz.xyz.gov/portal'), 'xyz', 0, ['Length', 'SURV_DATE', 'EXEMPT_COD'], false);
var sum_flexible = Sum(Filter(fs_flexible, sql), 'Length')
var fs_rigid = FeatureSetByPortalItem(Portal('https://xyz.xyz.gov/portal'), 'xyz', 1, ['Length', 'SURV_DATE', 'EXEMPT_COD'], false);
var sum_rigid = Sum(Filter(fs_rigid, sql), 'Length')
var fs_concrete = FeatureSetByPortalItem(Portal('https://xyz.xyz.gov/portal'), 'xyz', 2, ['Length', 'SURV_DATE', 'EXEMPT_COD'], false);
var sum_concrete = Sum(Filter(fs_concrete, sql), 'Length')
var fs_gravel = FeatureSetByPortalItem(Portal('https://xyz.xyz.gov/portal'), 'xyz', 3, ['Length', 'SURV_DATE', 'EXEMPT_COD'], false);
var sum_gravel = Sum(Filter(fs_gravel, sql), 'Length')
var sumDict = {
'fields': [{'name':'Completed_Miles', 'type':'esriFieldTypeDouble'}],
'geometryType': '',
'features':
[{'attributes':
{'Completed_Miles': (sum_flexible + sum_rigid + sum_concrete + sum_gravel)
return FeatureSet(Text(sumDict)); Thanks in advance!
