Hi, I'm working on ArcGIS Pro Dockpane.
XAML:
<UserControl x:Class="Projekt.SelectedLineLengthDockpaneView"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:ui="clr-namespace:Projekt"
xmlns:extensions="clr-namespace:ArcGIS.Desktop.Extensions;assembly=ArcGIS.Desktop.Extensions"
mc:Ignorable="d"
d:DesignHeight="300" d:DesignWidth="300"
d:DataContext="{Binding Path=ui.SelectedLineLengthDockpaneViewModel}">
<UserControl.Resources>
<ResourceDictionary>
<ResourceDictionary.MergedDictionaries>
<extensions:DesignOnlyResourceDictionary Source="pack://application:,,,/ArcGIS.Desktop.Framework;component\Themes\Default.xaml"/>
</ResourceDictionary.MergedDictionaries>
</ResourceDictionary>
</UserControl.Resources>
<Grid>
<Grid.RowDefinitions>
<RowDefinition Height="Auto"/>
<RowDefinition Height="*"/>
</Grid.RowDefinitions>
<Button Grid.Row="1" Command="{Binding CmdSelection}" Margin="5" Content="Zvol linii"
Style="{DynamicResource Esri_Button}" />//here is warnings
<Button Grid.Row="2" Command="{Binding CmdShowSelectedLines}" Margin="5" Content="Načíst tabulku"
FrameworkElement.Style="{DynamicResource Esri_Button}" />//here is warnings
<DataGrid Grid.Row="3" Margin="5" HeadersVisibility="Column" IsReadOnly="True"
ItemsSource="{Binding Path=LineSelectionSet}"
SelectionMode="Single" SelectionUnit="FullRow"
Style="{DynamicResource Esri_DataGrid}" AutoGenerateColumns="True"
SelectedItem="{Binding LineSelection}" HorizontalAlignment="Stretch">//here is warnings
</DataGrid>
<Grid Grid.Row="4" Margin="5">
<Grid.ColumnDefinitions>
<ColumnDefinition Width="120" />
<ColumnDefinition Width="*" />
</Grid.ColumnDefinitions>
<TextBlock Grid.Column="0" Text="Celková délka [m]:" Style="{DynamicResource Esri_TextBlockH3}" />//here is warnings
<TextBox Grid.Column="1" Text="{Binding TotalResult}" TextAlignment="Right" IsReadOnly="True" HorizontalAlignment="Stretch"/>
</Grid>
</Grid>
</UserControl>And I don't know about this at all:
Has it happened to someone or does anyone have experience with it?
Thank you for the advice.
David
